DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Dimmer Dilema
This topic originated from the How to page called Replacing a one-way light switch with a dimmer switch
Click here to return to the page called Replacing a one-way light switch with a dimmer switch.
  View previous topic :: View next topic
Author Message
talula
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 23, 2007 9:12 pm    Post Subject:
Dimmer Dilema
Reply with quote Thanks
I have tried to wire a one way dimmer as the old switch was wired and the light came on but would not dim. The original switch was wired as follows; 2 brown wires into L1, one brown wire into L2 and an earth into the back of the casing, there are also 3 blue wires coming out of the wall which all go into a block cable connector with nothing coming out of the other side.
The dimmer has the following connectors; L1, L2, a wavy line with an arrow going through it and an earth.
Any suggestions on how I can get it to work?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
comms
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 23, 2007 9:35 pm    Post Subject:
Try putting the two browns into the terminal with the arrow/wavey line.
The single brown into L1.
Leave blues in the connector block.
Connect the earths to the earth terminal.
__________________
prior planning & preparation prevents p*** poor performance.
Back to top
 Alert Moderators
talula
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 24, 2007 10:50 am    Post Subject:
Works perfectly. Thank you very much.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Junction box dilema & smoke hoods 4 580 Tue Jun 21, 2005 7:50 am
kitchen lighting dilema. 10 560 Tue Mar 27, 2007 8:27 pm
2 way switch dilema 9 400 Mon May 02, 2005 7:45 pm
Interesting summerhouse dilema 19 520 Tue Sep 22, 2009 8:13 pm
Warm Dimmer switch mains voltage halogens 4 420 Fri Oct 26, 2007 6:13 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
