DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Baxi 105e Instant - Slow Heating???
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
jd_hants
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 24, 2007 4:35 pm    Post Subject:
Reply with quote Thanks
On CH demand, boiler fires up, pump runs, gradually heats up, reaches max temp (80 deg led) in about 30 seconds, flame extinguishes and pump continues to run until temp decreases to 30 deg led before the boiler fires up again?
Result is that the rads get hot but not too hot to touch. Problem is that they dont seem to radiate enough heat to actually raise the temp of the rooms to much more than 19/20 degrees. This is despite TRVs being on max.
Have checked all rads and they didnt need bleeding. Boiler pressure constant at about 1.5-2 bar. DHW demand / instant DHW demand all seems to work properly (i.e. switching on/off when needed and returning to CH mode afterwards).
I have about 13 rads in all. If I switch off some of them then YES some of remaining ones are too hot to touch.
Wondered whether the pump isnt up to the job??? It was replaced during the summer - its the same as the original but has the words "Low Energy" on it. Do you think this pump is not beef˙ enough??? Or maybe the entire boiler is just not capable of heating so many rads??? Maybe I need to replace it with something with a higher central heating system capacity???
Would appreciate anyones thoughts on the matter.
Many thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
baxpoti
from United Kingdom
Thanked: 34 times
PostPosted: Sat Nov 24, 2007 4:43 pm    Post Subject:
It's getting up to 80° too quick.
Start with checking the return filter is not blocked.
Back to top
 Alert Moderators
jd_hants
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 24, 2007 4:53 pm    Post Subject:
Just for information : just had another look at boiler. When the temp reduces down to 40 led, the pump contines to run for about 3 minutes or so before the boiler fires up again!
I guess a better question would have been:
What is the criteria for the flame being extinguished in CH mode. CH demand is still active (i.e. room stat set higher than room temp) and boiler temp set to maximum.
(do you think it may be overheating because the pump cant shift enough heated water???). Just a guess!
Thanks again
Back to top
 Alert Moderators
jd_hants
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 24, 2007 4:55 pm    Post Subject:
Thanks for the reply. That sounds logical as I had noticed that the return is always only warm to the touch.
Will go and check.
Back to top
 Alert Moderators
jd_hants
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 24, 2007 5:49 pm    Post Subject:
OK - return filter bit black but clear.
Timed whole process:
Pump starts, boiler fires up
Temp rises to 80 degrees from 40 in about 25 seconds
Remains at the temp for further 30 seconds - sounds like it is still heating the water up as pump gets bit noisier - sounds like its either pumping loads of aerated water or its actually boiling!!!!
Flame extinguishes but pump continues
Gradually cools down to 40 in about a further 30 seconds
Continues to run at 40 for a further 1 minute before repeating again
Have just turned all the rad lockvalves to fully open to see whether boiler will remain on for longer if it can pump the heated water away easier.
Back to top
 Alert Moderators
jd_hants
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 24, 2007 6:16 pm    Post Subject:
Boiler does seem to stay on longer before 'tripping???'. I think I mustbe on the limit or exceeded the 80 litre maximum capacity.
Is there a heftier pump I could upgrade to or is it the entire boiler which I would have to replace to upgrade to, say, a 100 litre capacity system??
Back to top
 Alert Moderators
baxpoti
from United Kingdom
Thanked: 34 times
PostPosted: Sat Nov 24, 2007 6:18 pm    Post Subject:
How hot is the flow pipe? Measured at least 1m away from boiler
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Sat Nov 24, 2007 6:33 pm    Post Subject:
Could it not be the divertor partialy sticking and just sending the water around the boiler with slight amount going to heating
Back to top
 Alert Moderators
baxpoti
from United Kingdom
Thanked: 34 times
PostPosted: Sat Nov 24, 2007 7:16 pm    Post Subject:
Patience old man!
Back to top
 Alert Moderators
jd_hants
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 24, 2007 10:12 pm    Post Subject:
OK - opening each of the lockshields "seems" to allow the boiler to run for a bit longer before the flame extinguishes. Trouble is now my farthest rad doesnt get so hot any more.
anyone know what the difference between the Grundfos 15-60 (original pump) and 15-60 Low Energy (replacement) is. Just wondered if is runs
slower or something. Cant find any spec on it on Grundfos site.
CH flow temp is approx 55degrees. Bit confused why boiler 80 degree light comes on if temp is only 55??? Although thermometer is just one of those pipe thermometers and might not be that accurate?
I read another thread earlier which refers to the strange bubbling noise coming from the pump as kettling??? Thats exactly what it sounds like. The hot water isnt being pumped away quick enough?!?!
Back to top
 Alert Moderators
jd_hants
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 24, 2007 10:21 pm    Post Subject:
ok thanks - How do I check the divertor valve???
Back to top
 Alert Moderators
jollyjingle
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 27, 2008 5:56 pm    Post Subject:
Re: Baxi 105e Instant - Slow Heating???
Many thanks
water not getting getting away from heat exchanger ,prob pump fault
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Baxi combi 105e instant central heating not turning off 5 240 Wed May 06, 2009 9:12 pm
baxi instant 105e no central heating 14 400 Sat Sep 05, 2009 3:08 pm
baxi combi instant 105e central heating boiler 5 300 Tue Sep 08, 2009 11:28 am
Baxi 105e Instant heating rads whilst CH is switched OFF? 2 140 Sat Nov 29, 2008 2:47 am
BAXI Combi Instant 105e Central Heating Problems 6 560 Fri Feb 20, 2009 11:40 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
