I am re-vamping my kitchen and removing the existing single oven and replacing with;
2 off Single Ovens Neff (not sure of rating???)
1 off ceramic Hob Neff (not sure of rating???)
As far as i can see the existing wiring, is not acceptable as the oven has been run off the ring ??? So I am going to run in a new feed from the consumer unit.
Appreciate any guidance on the following:
Q. Should I use a 45A (10.8kW) or 30A (7.2kW) feed, (6mm2) considerate I can't find any info on the ratings of the appliances, not even on the Neff site??
Q. Can I run all 3 appliances from this feed from the consumer unit, if so do I need 3 control units (DP Switch) or will 1 be ok?
Q. If 1 is OK? Can I run 3 spur's from the control unit or should I run 1 and link it from appliance to appliance in series?
Anything else anyone can guide me on greatly appreciated.
Simon.
Simon.
