I went on holiday in June 2007 and turn the system off at the gas tap just outside the boiler. Ever since then the boiler cuts out sometimes after 3 days and once after 3 months. The boiler has always been looked after with regular servicing and also, top ups with inhibitor so the system is very clean, as is the flue. It always lights up straight away and heats up the hot water and heating very quickly with no problems, it also recently had a new thermal coupling fitted.
Can you throw any light on the problem.
