DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fitting a Socket
This topic originated from the How to page called Installing a electrical mounting box
Click here to return to the page called Installing a electrical mounting box.
  View previous topic :: View next topic
Author Message
PDsir
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 19, 2004 11:43 am    Post Subject:
Fitting a Socket
Reply with quote Thanks
Is there a minimum height that a socket must be above floor level
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ZenStalinist
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 19, 2004 12:01 pm    Post Subject:
It shouldn't be mounted in a skirting board, the building regs reccomend 800mm to 1200mm though this is a reccomendation for new buildings and extensions, and is not mandatory.
Back to top
 Alert Moderators
dingbat
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 19, 2004 12:27 pm    Post Subject:
Er, I think you'll find it's between 450 and 1200mm, which is bad enough - imagine if all your sockets had to be two-and-half-feet above the floor!! But Zen's quite right about existing installations y- ou can mount them wherever they are not likely to be damaged - hence not sticking them on skirting boards.
Back to top
 Alert Moderators
ZenStalinist
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 19, 2004 2:57 pm    Post Subject:
Back to top
 Alert Moderators
TaxTracker
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 09, 2004 11:39 am    Post Subject:
A fine line?
Just to tighten up on the definitions: icon_wink.gif
A band from 450mm to 1200mm is specified for the installation of switches and sockets. It is anticipated that switches will be at the top end of this band and TV sockets, telephone jack points, flex outlets would be at the bottom end.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Fitting a socket on a wall 3 380 Mon Jun 12, 2006 6:25 pm
fitting a 500w light into a house plug socket 9 440 Sun Sep 06, 2009 9:56 am
Advice with fitting new wall socket fascia 4 200 Wed Sep 09, 2009 12:42 pm
fitting twin plug socket into my garden shed 4 240 Thu Sep 10, 2009 3:41 pm
Fitting a new socket in a garage 19 920 Mon Jun 12, 2006 4:42 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
