Can you remove the head without draining the system?
Heating's playing up this evening, quickly narrowed it down to no output on the orange wire (and all works fire if you hot-wire the boiler to the thermostat output).
Look like a new head is needed, so I just tried losening the screws and got some drips out so quickly re-tightened. Should the valve itself be sealed, or do I need to drain to replace the head?
