DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hinges for a difficult situation!
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
Guest
PostPosted: Sat Nov 16, 2002 4:28 pm Reply with quote
I need to find a hinge which will attach a cover panel straight to a wall, so that the side of the door is right against the wall and the door can still open flat 90 degrees. The problem I am having at the moment is that the door only opens to about 45 degrees before the side of the door presses against the wall, preventing it from opening. Is there a hinge will bring the door outwards, away from the wall, before opening 90 degrees, so that the door can openly freely, right back to the wall? Please help!!!
Back to top
 Alert Moderators
Guest
PostPosted: Sat Nov 16, 2002 4:38 pm Reply with quote
sit the door in the recess put the hinges on the front of the door then it will open 90 degrees simple.
Back to top
 Alert Moderators
craftsman
from United Kingdom
PostPosted: Sun Nov 17, 2002 11:35 am Reply with quote
The hinge you require is called a parliment hinge.
This allows the door to be folded flat to the wall.
Most diy outlets do not stock these hinges, so try local builders merchants.
Good luck.
Back to top
 Alert Moderators
DAZB
from United Kingdom
Thanked: 90 times
PostPosted: Fri Nov 29, 2002 10:57 pm Reply with quote
You can also use a special type of kitchen unit hinge that will open to around 180 degrees.It sort of telescopes out as it opens and may be useful.
Back to top
 Alert Moderators
devhill
from United Kingdom
PostPosted: Wed Jul 02, 2003 10:00 am Reply with quote
I'd find that useful, any idea what its called or where I might go to get one?
My problem is a bit more difficult because I'd also like to have a window on each side of my door with a window ledge.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Wed Jul 02, 2003 7:47 pm Reply with quote
Parliment hinge
See this.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Thu Jul 03, 2003 6:30 am Reply with quote
you can get them from here last one at the bottom
Back to top
 Alert Moderators
DAZB
from United Kingdom
Thanked: 90 times
PostPosted: Thu Jul 03, 2003 7:55 pm Reply with quote
I have had a bit of a browse and this is the closest thing I can find for you.
http://www.dks-online.co.uk/acatalog/hinge_fittigs.html
I think the 165 Clip on Hinge about half way down the page is the most suitable.
You could also try a visit to your local Kitchen supplier and ask them for the Telescoping hinges. They are mostly used on the Corner cupboards so you can get full access inside with the door opening more than a standard hinge.Hope this was some help to you.
Back to top
 Alert Moderators
HandyMom
from United States of America
PostPosted: Tue Jul 29, 2003 3:37 am Reply with quote
Rockler Woodworking and Hardware (www.rockler.com) in the USA carries these European hinges by Blum that seem to fit your needs. They are frameless hinges with a lifetime warranty. They have hinges of every imaginable type, including 60-degree bi-fold hinges, 90-degree "mini_ hinges, 95-degree "thick door" hinges, 120-degree, 165-degree, etc. Their "greatest opening capacity" hinge is a 170-degree hinge that can be adjusted in 3 directions -- side-to-side, depth, and height -- AFTER installation. Rockler also sells special drill jigs that enable you to conceal the hinges completely by drilling cup holes. I bet these hinges are available in the UK, since they are, I believe, of European manufacture. Good luck! icon_wink.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Difficult Screw 14 2500 Thu Nov 13, 2008 2:05 pm
Difficult to insulate 2 4880 Wed Nov 30, 2005 3:16 pm
Hinges - straight or cranked 5 360 Tue Jan 15, 2013 11:17 pm
Kitchen hinges 4 140 Wed Dec 28, 2011 10:52 pm
Hook & band gate hinges - fitted correctly? 9 5000 Mon Jan 28, 2013 10:02 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
