DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Double glazing
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
Assen9
from United Kingdom
PostPosted: Sat Nov 16, 2002 9:33 pm Reply with quote
I am having Double glazing fitted and usually leave the professionals to get on with the job, but I did notice that when the frames were fitted they left the old ( loose ) mortar in place and put the frames on top. Is this ok? Or should they have put new mortar in?
They are coming back to make this good, but they want to use sealant, is this a good replacement or should mortar be used?
TIA.
Back to top
 Alert Moderators
Guest
PostPosted: Sat Nov 16, 2002 9:56 pm Reply with quote
any mortar which is loose is better replaced, it would have been better to rake it out and re-point under the window sealer is for down the side of the frames......ian
Back to top
 Alert Moderators
Assen9
from United Kingdom
PostPosted: Mon Nov 18, 2002 12:56 am Reply with quote
Thanks Ian,
what would the best course of action to take now? Try to mortar under the sills with the windows in place? ( not very effective ) or to fill with some other material? Silicon does not seem to be the best for this job, but does seem favourite with the fitters....
Thanks again.
Back to top
 Alert Moderators
Guest
PostPosted: Mon Nov 18, 2002 1:32 am Reply with quote
yes you can still re-point under the window,grind out the old mortar then use a small pointing trowel to fill it in,mix wants to be 3 sand 1 cement......ian
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Recommend Double Glazing Company? 2 1380 Wed Feb 26, 2003 8:27 am
triple glazing or double 7 240 Sat Feb 28, 2015 4:48 pm
replace double glazing units 3 100 Sun Mar 23, 2014 10:43 am
Post double-glazing damp 6 3040 Tue Jan 14, 2003 11:04 am
Temporarily removing double glazing 4 16480 Wed Jan 22, 2003 10:09 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
