Is this a Radial Circuit off a Spur?
1 Jan 2008
Cardiff
Just wanted to check whether what I had in mind for the Kitchen was permitted. New kitchen in the middle of being fitted and I have spurred a double socket from the ring to provide a feed for tumble-dryer TD and dishwasher DW. I now want to fit under-pelmet lighting to 4 cupboards and the lighting kit I have is powered via a plug.
My question is, can I scrap the original spur feed for the TD and DW and instead run a new spur into a 13Amp Fused Spur...then from this run a double socket for the DW/TD....and then further run a feed to a fused switch which will power the pelmet lights?
RING SOCKET --> 13a FUSED SPUR --> DOUBLE SOCKET --> 13a SWITCH FUSED SPUR
Appreciate your thoughts on this...
A double socket with a tumble dryer and dishwasher plugged into it is not really a good idea due to possible overheating of the socket.Also the load will be too great for the 13A fuse in the FCU.
I take you are aware of Part P of the Building Regulations?
Thanks for the note...I now have a local NIC electrican coming to the house on Friday to review this work! Thanks for the prompt response.
