giardini
Joined: 02 Aug 2004 Posts: 1 Location: United States of America Thanked: 0 times
Starrq77
Joined: 08 Feb 2006 Posts: 1 Location: Canada Thanked: 0 times
Posted: Wed Feb 08, 2006 1:15 pm Post Subject: Removing hair dye from carpet! |
I have a wonderful product called "Goo Be Gone".....not only did it remove week old hair dye from my light carpet, but it seems to remove everything from anything! I've also used this product to remove grease from clothing, ink from clothing and other stains from carpeting. There are directions on the back for different things and I find if you just follow these it works wonderfully! Also it has a wonderful orange smell! I'm in Canada but it says this product was made in the US. Good luck! |
Nestor_Kelebay
Joined: 19 Jan 2006 Posts: 494 Location: Canada Thanked: 0 times
Posted: Wed Feb 08, 2006 7:06 pm Post Subject: |
Giardini:
Try using bleach straight out of the jug on an inconspicuous spot on the carpet. If the carpet is solution dyed (which means the color comes from tiny colored particles added to the plastic before drawing it into a fiber, then you can use bleach on the carpet without harming the carpet. All 100 percent Olefin carpets are solution dyed. If you have an Olefin carpet, or a solution dyed polyester or solution dyed nylon commercial carpet, you can use bleach to remove otherwise impossible stains from it, without harming the carpet.
But, check to see if bleach takes the color out of the carpet in an inconspicuous spot, first. If it does, then try using a solvent to dissolve the dye like paint thinner maybe. |
tezza1
Joined: 16 Jul 2009 Posts: 1 Location: London, United Kingdom Thanked: 0 times
Posted: Thu Jul 16, 2009 1:05 pm Post Subject: hair dye in carpet |
soap, vinegar and warm water |
