DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Unvented System....system or regular boiler ?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
topgazza
from United Kingdom
PostPosted: Mon Jan 07, 2008 5:12 pm Reply with quote
looking at the Worcester /Bosch website they suggest a system boiler for my house because it contains an expansion tank built in ..yet I have an unvented pressurised system so wouldn't I need just a regular condensing boiler ?
The site only mentions a 1 year warranty as well, extended to two if you return the reg card withing 30 days...
Back to top
 Alert Moderators
mikej2005
from United Kingdom
Thanked: 8 times
PostPosted: Mon Jan 07, 2008 5:33 pm Reply with quote
'System' boilers are used on unvented/pressurised systems (like yours) and 'conventional' or regular boilers are used on vented systems (where you have an expansion tank in the loft)
Back to top
 Alert Moderators
mikej2005
from United Kingdom
Thanked: 8 times
PostPosted: Mon Jan 07, 2008 5:36 pm Reply with quote
P.S. Some unvented systems utilise separate expansion vessels, so by the sounds of it WB are implying that you could do away with that if you chose one of their system boilers, as they they are inbuilt.
Back to top
 Alert Moderators
topgazza
from United Kingdom
PostPosted: Mon Jan 07, 2008 6:08 pm Reply with quote
Thanks Mike...that makes sense...not sure if I have an expansion tank as there are two "vessels" attached ..one is the pressure tank that I top up from time to time but there is another above the cylinder.
I guess whoever comes round to do the job can decide but I wouldn't want to remove something...extra work/cost/potential problem.....so I'd probably go for the regular as the system wouldn't give me any extra....
Back to top
 Alert Moderators
mikej2005
from United Kingdom
Thanked: 8 times
PostPosted: Mon Jan 07, 2008 6:19 pm Reply with quote
As far as Worcester Bosch's usage of the terms go, a 'system' boiler can only be used on a sealed/pressurised/unvented system and a 'regular' or 'conventional' boiler can only be used on an open/vented system.
If I've understood this correctly and your current system is pressurised, then you'll have to have a system boiler.
If an inbuilt expansion vessel is the only difference between the two, then I don't know whether a conventional boiler can be used on an existing sealed system in conjunction with a separate expansion vessel though - I doubt it instinctively, but that's probably one for the pro's, that one !
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Combi, system or regular boiler? 16 1420 Sun Aug 30, 2009 12:16 pm
regular vs system boiler 6 420 Wed Nov 25, 2009 9:10 am
Potterton Profile 100e - system or regular boiler? 9 140 Sat Aug 06, 2011 5:41 pm
Regular boiler, system boiler, what`s the difference? 12 580 Fri Jun 19, 2009 10:02 pm
Combi Vs Traditional Regular Conventional System 11 5320 Mon Nov 13, 2006 6:45 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
