DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Anyone got any tips for feeding cable in conduit?
This topic originated from the How to page called Routing cable
Click here to return to the page called Routing cable.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics UK
  View previous topic :: View next topic
Author Message
GaryMonster
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 12, 2004 9:47 pm    Post Subject:
Reply with quote Thanks
Hi, has anyone got any tips for feeding 2x 2.5mm (Twin & Earth) cables down 20mm conduit?
Is there some substance which makes this process easier like washing up liquid? What do the pros do? I found it easier to do this before attaching the conduit in the wall, but I still struggled with pushing the pair of cables through.
Cheers
Gary
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
dingbat
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 12, 2004 10:07 pm    Post Subject:
Re: Anyone got any tips for feeding cable in conduit?
You can get cable lube in a spray can from any electrical wholesalers. Washing up liquid will do the job but may have adverse effects on the PVC sheathing over time. But the real reason you're having difficulty is that T + E isn't designed for installation in conduit and it's a real b**ger to get round bends.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Thu Aug 12, 2004 10:20 pm    Post Subject:
the thing with singles is you have to use conduit all the way
Back to top
 Alert Moderators
BR
from Ireland
Thanked: 0 times
PostPosted: Thu Aug 12, 2004 10:24 pm    Post Subject:
strictly speaking you shouldn’t be putting 2 x 2.5mmsq cable down conduit in the first place 45% spacing factor. A minor issue here really.
Back to top
 Alert Moderators
TexMex
from United Kingdom
Thanked: 0 times
PostPosted: Thu Aug 12, 2004 10:28 pm    Post Subject:
Attach a rubber hose to a vacuum cleaner and push it against one end of the conduit. Offer up the end of a nylon cord the other and allow it to be drawn through. Once it is threadled all the way, tie it to your cable and pull it.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Fri Aug 13, 2004 12:36 am    Post Subject:
Use 25mm conduit with T & E or use singles with 20.
You are opening the bends etc to allow you to draw each section in individually, not all in one????
Back to top
 Alert Moderators
Millennium_Boy
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 13, 2004 7:44 pm    Post Subject:
conduit
20mm conduit is too tight to allow two t+e cables down it safely - read the cable factors in the on-site guide carefully.
_____________________
moderator
locked to stop post being hi-jacked again
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Electrics UK All times are GMT
Page 1 of 1
Jump to:
30 amp rewirable fuse feeding radial with 4mm cable 16 700 Mon Jul 13, 2009 8:36 pm
BACK FEEDING A 110 CTE TRANSFORMER 14 1680 Sat Jan 20, 2007 6:06 pm
Feeding new wires down a Stud Wall 59 1740 Fri Apr 09, 2004 6:06 pm
T&E feeding CU from Meter 9 460 Fri Dec 08, 2006 9:33 am
Hmmm 10mm T&E feeding a CU?!? 2 360 Sun Feb 18, 2007 9:03 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
