Bosch Dishwasher SGS4012GB/07 Will not heat water or dry
24 Jan 2008
Middlesex
Any ideas why my Bosch unit is not heating water or drying dishes - the problem has been getting progressively worse? Could it be an element problem if so is it relatively easy to replace? Would this explain why the tablet remains semi-dissolved after the cycle.
Thanks,
I've just had the same problem with my Bosch,
From what I have found it will be the heating element.
New elements for most makes are available for less than £50 but the bosch ones seem a lot harder to find, the cheapest price I could find was more like £150 direct from bosch.
Not worth it, espicially as you've then got to take it apart and hope it was that at fault.
I've just bought a new one for £200 delivered
Thanks for the feedback - where did you get the Bosch d/washer for £200 from.
Cheers,
Stuart
