Hi guys,
I moved into my house 18 months ago and the central heating system has worked perfectly during that time. The house was built circa 15 years ago so I think the boiler is the original one.
Yesterday when I got up I noticed the house was very cold - the central heating wasn't working. The hot water was fine and its thermostat has switched off the boiler. The room thermostat seems to be working ok in as much as it is switching (I can hear it click) when the temperature dial is moved and the indicator lights are lit up.
If I turn up the boiler thermostat the system kicks in and works fine (including the central heating) until the water reaches the new temp.
Also, if I increase the setting on the boiler thermostat (the one on the case) the boiler kicks in and everything is fine.
I'm guessing this is an electrical problem but not sure what to blame!!
The system use a 3 way valve so water and CH are independant.
Any ideas?
Cheers
Any ideas?
Cheers
