DIYnot
Local | Network
   DIYnot > Forums
Local | Network
How to take lid off a dual flush cistern?
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
drmrbrewer
from United Kingdom
PostPosted: Tue Aug 17, 2004 10:01 pm Reply with quote
OK, I feel like a complete eedjit asking this question, but I inherited a dual flush cistern with our house, a simple type with two push buttons on top shaped together to form a circle. It's a Gala type if that helps.
Question: how do I get the lid off?! The push button mechanism on top has a ring retainer around it of some sort which I think is preventing the lid coming off, but the retainer doesn't seem to rotate.
Any help appreciated!
Mike
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1094 times
PostPosted: Tue Aug 17, 2004 10:04 pm Reply with quote
Answered recently - try Search. Push one "button" down and you might see a little groove for a thumbnail/screwdriver in the side of the one which is still up. Use to prise it up, then the first, then all should be clear.
Back to top
 Alert Moderators
drmrbrewer
from United Kingdom
PostPosted: Wed Aug 18, 2004 12:09 pm Reply with quote
Thanks ChrisR, I'll give that a go. I did try a search, but my searching abilities are clearly as good as my lid-removal abilities!
Bet you don't get much call for plumbing jobs in Antarctica.
Mike
Back to top
 Alert Moderators
petergordonbrown
from United Kingdom
PostPosted: Sat May 31, 2008 2:18 pm Reply with quote
Thanks again Chris, a few years later I have found this with a google search and got the info I was looking for. Did you ever think that your answer would last and last? Thanks again for helping in a tight spot.
peter brown
Back to top
 Alert Moderators
movinghands
from South Africa
PostPosted: Wed Sep 23, 2009 7:24 am Reply with quote
OK, I must be an even bigger "eedjit" because I've got as far as popping off the "Buttons" but it still ain't clear to me how to get the lid off!! The remaining fitting still has a hold and it feels like I'll break it if I try to prise it up.
Know what I mean? This toilet is a Vaal.
Back to top
 Alert Moderators
tonybhoy
from United Kingdom
Thanked: 1053 times
PostPosted: Wed Sep 23, 2009 7:51 am Reply with quote
Should be a big plastic screw-head visible, if there is just un-screw it if there isn't then the entire fitting unscrews.
Tony
Back to top
The following user says thank you to tonybhoy for this useful post:
movinghands (26 Sep 2009)
 Alert Moderators
bathstyle
from United Kingdom
Thanked: 65 times
PostPosted: Wed Sep 23, 2009 8:28 am Reply with quote
Ideal Standard specifically brought out these difficult to get into cisterns so that people wouldn't keep taking the Lids off.
After a couple of years of this type being sold they were inundated with phone calls to their technical department by DIYers so they decided to chage the design to something that would simply lift off.
Back to top
 Alert Moderators
forthy
from United Kingdom
PostPosted: Thu Dec 29, 2011 4:45 pm Reply with quote
Thanks ChrisR for your instructions I have an Ideal Standard one just as described we got into it thanks to your instructions and fixed the problem with the ballcock icon_biggrin.gif Well Happy now!
Back to top
 Alert Moderators
rolling
from United Kingdom
PostPosted: Mon May 27, 2013 11:07 am Reply with quote
Managed to get the buttons out of my B&Q Dual Flush unit, but there's no screw beneath and the white posts stick through preventing me from uncrewing the surround. (You cannot push them below the ring).
Any ideas gratefully received.
Here's a photo of the lid...
Back to top
 Alert Moderators
Charnwood
from United Kingdom
Thanked: 510 times
PostPosted: Mon May 27, 2013 11:50 am Reply with quote
Have you tried easing the outer ring upwards, away from the lid?
Back to top
 Alert Moderators
denso13
from United Kingdom
Thanked: 348 times
PostPosted: Mon May 27, 2013 12:31 pm Reply with quote
Unscrew the outer ring? Sometimes takes a bit of fiddling.
Back to top
 Alert Moderators
rolling
from United Kingdom
PostPosted: Mon May 27, 2013 12:42 pm Reply with quote
Yes. Tried levering the ring up, but it seems to be trapped at the back. May just need more courage, but do not want to break it.
As I said, you cannot rotate ring because prevented by white plastic posts - short flush sticking through hole and long flush being in slot.
Unfortunately, I did not install it, so did not see how it went together.
Back to top
 Alert Moderators
willsgas
from Italy
Thanked: 62 times
PostPosted: Mon May 27, 2013 1:41 pm Reply with quote
It should unscrew, you may find that the white rods are part of the button mechanism.
Back to top
 Alert Moderators
picasso
from United Kingdom
Thanked: 1220 times
PostPosted: Mon May 27, 2013 2:06 pm Reply with quote
Try pulling the rods out seperately and then unscrewing the chrome ring.
Back to top
 Alert Moderators
HERTSDRAINAGE2010
from United Kingdom
Thanked: 804 times
PostPosted: Mon May 27, 2013 2:50 pm Reply with quote
Does the lid lift straight off? if not then turn the whole thing anti-
clockwise.
Andy
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Conceala 2 cistern with Gerberit push button dual flush 3 1080 Sun Mar 01, 2009 5:37 pm
Replace old cistern with dual flush 3 7120 Wed Oct 24, 2007 12:34 pm
button on dual push flush cistern stuck 3 2140 Thu Sep 13, 2007 7:05 pm
Cistern - dual flush button - I cannot get the top off 5 880 Thu Mar 12, 2009 2:41 pm
Dual Flush Cistern keeps filling 6 1440 Tue Nov 25, 2008 12:07 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
