DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Repair Cracked Limestone Hearth
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
Wilbo
from United Kingdom
PostPosted: Wed Feb 06, 2008 12:47 pm Reply with quote
Hi All
The hearth for our new Limestone fireplace was recently involved in an 'incident' icon_redface.gif in our garage in which it ended up getting cracked. When the pieces are tight together the crack is only visible when very close up, but i would like to permanently re-join the pieces together.
I've had a look round the web looking for advice regarding repair mortars/compounds and have found some products available in the US but can't seem to find any here in the UK.
Can anyone adsive the name/brand of a product to help me out? The best advice I have found to far is a clear epoxy resin mixed with limestone dust.
Any help or advice would be most appreciated!
Cheers
Wilbo
Back to top
 Alert Moderators
crazycanuck
from Canada
PostPosted: Thu Feb 07, 2008 8:37 pm Reply with quote
google says check-
Stonetec-uk.com good luck
Back to top
 Alert Moderators
JerryM
from United Kingdom
PostPosted: Sun Feb 24, 2008 10:02 am Reply with quote
i know that limestone fireplaces (backplates) can come in sections (as opposed to 1 piece). they are then assembled on installation using a white cement/mortar.
i would try you local fire shops to get some of the cement. once the cement has gone off then the area can be "sanded" to improve the aesthetics albeit you will never be able to completely remove the crack.
i can advise on the sanding if you get to that point. Itís quite simple and produces good results.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Limestone fire surround and hearth. (fixing) 3 2200 Wed Nov 25, 2009 3:46 pm
Repair for cracked shower tray 3 420 Sat Feb 05, 2011 2:10 pm
Cracked Bath repair? 8 2880 Sat Aug 14, 2010 10:37 am
Limestone Mantel-How Do I Secure The Metal Fixing Brackets? 3 1440 Sat Dec 22, 2007 4:11 pm
HELP PLEASE - FITTING OF A LIMESTONE FIRE SURROUND 2 3020 Tue Feb 17, 2009 11:24 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
