I'm familiar with the type of try below, which is built into the brickwork as work progresses. These can also be fitted into existing brickwork by chopping bricks out, inserting the tray & re-bricking.
However, is there anything else available that doesn't require bricks to be chopped out? Maybe something where you chop out a line of mortar & insert it in through there? I need to insert cavity trays in the existing house wall that my extension is joined to & just wondered if there was anything available that was easier to use?
