DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Vokera Compact Se 28 - Occasionally locking out after 10 min
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
paulrushton
from United Kingdom
PostPosted: Wed Feb 13, 2008 5:24 pm Reply with quote
Hi
We have a troublesome Vokera Compact Se 28. It recently about 1 month ago have a new ignition board that connects to the PCB. Up until today it worked fine. I put the heating on this morning and it fired up from cold and heated the radiators for about 10 minutes before then locking out. The red light would then flicker green after a couple of minutes and it would attempt to fire up again but lock out. The pump sounds to be running constantly throughout all this.
If I turn it off on the timer and the selector knob to off, the boiler still tries to fire up and restart. The only way to stop it from continually restarting is to kill the mains power.
If left for 10 minutes and turned back on the boiler will then flash happily a green light. This though after another 5 mins then goes red and the whole thing starts again.
I left it this morning and have just tried again tonight. It ran fine for 10 minutes (from cold) again before doing all of the above.
I think it may be the central heating thermistor that is on its way out but access is tricky to check the resistance of it. Every now and then it shows a solid amber light.
Does anybody have any ideas please???
The hot water side of things seems fine (at the moment).
Paul
Back to top
 Alert Moderators
paulrushton
from United Kingdom
PostPosted: Wed Feb 13, 2008 5:54 pm Reply with quote
The orange.amber light I referred to was because I had not connected up the DHW thermisttor as I was trying to see where the pins were to help get a multimeter in.
I tried disconnecting the CH thermistor when off or on and it produces the same kind of results that it is doing when locking out. Could it be the CH thermistor thats knackered. I have changed the hot water one about 6 months ago as it was getting hot and cold water and think it may be this. I'm not sure how to drain the system etc so dont want to start taking it apart and having to refill it.
Any help is greatly recieved.
Back to top
 Alert Moderators
paulrushton
from United Kingdom
PostPosted: Wed Feb 13, 2008 9:00 pm Reply with quote
Any ideas anybody?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Baxi back-boiler occasionally won't fire up and locks out? 3 300 Mon Mar 29, 2010 7:29 am
CH occasionally not working but HW OK 2 180 Thu Nov 05, 2009 10:22 am
Whining noise occasionally when CH on, Potterton Suprima 60 10 360 Sat Oct 16, 2010 9:31 pm
HW Tank Pressure Relief Valve occasionally dripping 3 60 Wed Aug 17, 2011 8:49 pm
Occasionally smelly toilet/basin mystery? 10 240 Mon Aug 25, 2014 12:33 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
