DIYnot
Local | Network
   DIYnot > Forums
Local | Network
cooker hood wiring ...
Author Message
alb
from United Kingdom
PostPosted: Sun Mar 02, 2008 11:23 am Reply with quote
Hi all,
am looking at wiring in a new cooker hood :
cable on hood is very short & the nearest socket is down behind the cooker (10 inches or so off ground)
We have a gas cooker & nothing is connected to this socket at the moment - no red cooker switch - just a single socket.
Have checked fuse box & it is supllied by it's own 32a MCB - marked 'cooker' (!).
rest of mains sockets are run from a seperate 32a MCB .
am guessing this would be to connect a hob or even ignition for gas cooker to?
would it be ok to spur from this socket up to the height of the cooker hood (directly up behind plasterboard where hood will go) coming out at an FCU at top of chimney ?
many thanks for any help.
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 226 times
PostPosted: Sun Mar 02, 2008 6:41 pm Reply with quote
You'll probably find that socket is fed by 6mm˛ cable. You will struggle to get another cable in there.
Its fine to use for gas ignition, that will plug in, it only consumes a few watts, plus the oven light icon_wink.gif
I would find another source of power for the hood.
Back to top
 Alert Moderators
alb
from United Kingdom
PostPosted: Sun Mar 02, 2008 7:48 pm Reply with quote
hi steve thanks for the reply,
ok guess I should spur from the sockets above worktop to the right of cooker then instead..
wanted to hide as much wiring as poss but to do it safely(!) -
which of these is best ? :
the next closet socket is to the right of cooker above worktop,
So I'll I spur to the side of the socket for the fcu, then channel in straight up to a flex outlet outside top of chimney & wire hood into that,
( leaving a bit of cable visible coming out of top of chimney)
or is it ok to channel flex from fcu behind splashback & then straight up to outlet inside of chimney, hiding all cable ?
plasterboard wall so shouldn't be too hard to sort out either way...
Back to top
 Alert Moderators
thompsk
from United Kingdom
Thanked: 1 time
PostPosted: Sun Mar 02, 2008 8:14 pm Reply with quote
Just a couple of thing there to bear in mind:
1. Ensure that the socket you will be connecting into is'nt a spur and that it is on a ring.
2. Make sure you can still access the socket for the hood.
3. This work is notifiable to your local council.
Back to top
 Alert Moderators
alb
from United Kingdom
PostPosted: Sun Mar 02, 2008 9:05 pm Reply with quote
hi thompsk,
thanks for reply,
2. would i need to wire a socket then at chimney, and plug in instead of a flex outlet with hood wired straight into it?
or do you mean it's best to have the socket / outlet outside of chimney as in my first pic ?
3. yep am looking into that part of the equation now !
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 1010 times
PostPosted: Sun Mar 02, 2008 9:38 pm Reply with quote
The socket does not need to be readilly accesible, as you are proposing to install an accesible isolator.
It should still be accesible for inspection, testing and maintanence.
IMO behind a removable chimney is fine.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sun Mar 02, 2008 9:51 pm Reply with quote
I went to fault-find a cooker hood recently, and the socket outlet was accessible only by removing the appliance, which had been incorrectly installed (with mounting screws accessible only from above, screwed in before the cupboards were installed), and only by damaging some tile grout and paintwork, which needed to be made good afterwards.
The fault: one plugtop fuse. icon_rolleyes.gif
The cost: two hours of work and some gnashing of teeth.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Cooker Hood Control Unit WIring 2 180 Wed Aug 03, 2011 1:49 pm
Wiring a cooker hood's DP fused unit to the cooker's socket? 12 260 Thu Jul 11, 2013 6:20 am
cooker hood wiring 3 540 Fri Dec 05, 2008 9:41 pm
Wiring cooker hood into cooker circuit? 3 100 Sun Aug 25, 2013 7:04 pm
Wiring an oven, hob, cooker hood and double socket 2 820 Tue Jun 30, 2009 6:27 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
