sorry but i disagree, the wavy line like this ~ indicates a.c. (alternating current) it also maeans the the dimmer is NOT for use on d.c. (direct current)
How do I wire a dimmer switch in an ordinary three-core cable leading from a 13amp plugtop to a spotlight over the bed? - i.e I'm not replacing a light switch in the house wiring.
