DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Push button cistern - water running into bowl
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
bakerboy1977
from United Kingdom
PostPosted: Sun Mar 16, 2008 3:48 pm Reply with quote
I had a dodgy ball valve and so replaced the whole mechanism. Since then I have noticed a small trickle of water running into the bowl from the cistern.
It's not an overflow issue as the trickle starts as the cistern is filling up i.e. even when the cistern is half empty. Any ideas? Is this constant trickle normal or is there a problem with the flush mechanism?
Back to top
 Alert Moderators
cashjob
from United Kingdom
Thanked: 13 times
PostPosted: Sun Mar 16, 2008 4:03 pm Reply with quote
You may have disturbed or broken something. Make sure that there is a good seal between the bottom of the syphon and the cistern, as water could seep between the two.
As you say its not the overflow, then this is the only other possibility
Back to top
 Alert Moderators
thirdreich
from United Kingdom
PostPosted: Sun Mar 16, 2008 4:08 pm Reply with quote
Do you remember the bad old days when we used to have problems?
These days we only suffer from 'issues'.
Suppose Gordon Brown must be telling the truth when he says things are getting better!!!!
Back to top
 Alert Moderators
phil007
from United Kingdom
PostPosted: Sun Mar 16, 2008 9:18 pm Reply with quote
On most of these cisterns the flush assembly is detachable by giving it a twist anti clock wise & lifting up, then you can examine the thin rubber washer to check for damage/debris icon_wink.gif
Back to top
 Alert Moderators
bakerboy1977
from United Kingdom
PostPosted: Thu Mar 20, 2008 2:25 pm Reply with quote
Does anyone know where I can buy one of these? I don't know what make or model it is. I've been to 4 or 5 different plumbing suppliers... no joy! Please help!
Back to top
 Alert Moderators
bakerboy1977
from United Kingdom
PostPosted: Thu Mar 20, 2008 6:52 pm Reply with quote
I've just found a label on the toilet... it was made by LECICO. Does anyone know who supplies Lecico spare parts icon_question.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Cistern constantly running into bowl 8 1100 Fri Mar 21, 2008 6:34 pm
Water constantly running into toilet bowl 9 240 Sun Mar 22, 2015 8:51 pm
running water from toilet bowl 3 960 Thu May 25, 2006 4:01 pm
Leak between cistern and bowl? 27 600 Sun Sep 15, 2013 8:08 pm
Modern toilet cistern leaks into the bowl 2 1540 Fri Aug 05, 2005 11:23 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
