Hello, I have a Vaillant Turbo Max VUW242/1E; 240 KW; 80,000BTUs
The central heating works ok but hot water is only available when central heating is ON. Even then, after 5-6 open-and-shut of hot water tap, there is no hot water. I have to reset boiler, only then hot water is available, again only for 5-6 open/shut of hot water tap.
Is this a problem with the valve? Which valve? Is this something that I requires a qualified Plumber?
Also how much will a plumber normally charge for this. I am happy to get a good plumber in who knows his stuff. And does he have to be Corgi regd?
Or could this be an issue with the timer? I have obtained a Honeywell timer STC600 but not sure if this will go with Vaillant boiler
Pls advice
regards
Amod
Pls advice
regards
Amod
