Glow-worm compact 75p problem
10 Oct 2006
Hampshire
Hi, I have a Glow-worm Compact 75p boiler which was new when we moved in 7 years ago. I have it serviced once every couple of years or so.
Recently it seems to be cycling on and off more frequently when the central heating is on. It will fire up for just a few seconds and then go off again (the pilot light doesn't go out). Plus every now and again (seems especially when it's very cold and there's a greater demand on the boiler for heating), it will do this very rapid clicking as if it is trying to fire up but can't. The pilot light still doesn't go out, and if I turn the heating off for a few minutes, it will be OK again when I turn it back on.
Of course it didn't do it when the service guy was here last time :evil: but has anyone got any idea what this could be?
Disclaimer - I have no intention of trying to repair my boiler, I just don't want to be told I need a new one when it's just a minor problem with a thermocouple or something.
Cheers!
Probably the PCB. The rapid clicking is a relay chattering.
You DO need a CORGI for this.
Rob, thanks. Yes, I'd get a CORGI guy out to do it for me.
Do you have a rough idea of what would be a reasonable charge for supplying and fitting a new PCB?
It might well not be the PCB.
Could be the APS or most likely just the fan being dirty.
The fan should be removed and cleaned every couple of years as they turn all the time and get very dirty.
Tony
The service guy took the fan out and cleaned it, so it's not that.
What's the APS (please excuse my ignorance)
The fan outlet connection on your model is a real paid to fit !
Its just possible that its not properly connected or has come loose.
The APS is a safety device to confirm the fan is turning before the gas can be turned on.
Tony
:evil:
corgi
Sounds like it could be a number of things then. I was hoping there'd be one simple answer!
The boiler is working, so I guess there's no real urgency as I'll hopefully be switching it to hot water only for summer fairly soon. I will get it looked at before next winter.
Thanks everyone for your contributions.
Lisa
