No hot water or central heating.
3 Apr 2008
Wiltshire
I seem to have a blockage in the pipes from my pump in the airing cupboard to my boiler. Everytime the boiler fires up, be it for the heating system or hot water system it comes on for only about 2 minutes then turns itself off. I have put a descaling solution via the header tank in my attic after draining down the system(done this twice in fact) without any success. I was thinking about getting someone in to do a power flush. Does anyone know how much this would cost, and more importantly would it work. Thanks for any advice that is given.
Sounds more likely to be an air lock.
Look in the FAQ and similar topics for suggestions.
Tony
Thanks for your quick response agile, but I couldn't find anything in the FAQ'S that could help me.
It has a header tank in attic, a 3way motorised valve, myson compact pump, microbore pipes feeding 7 radiators, hope this is enough information.
It is getting warm, but its also running, when i change the speeds from 1 to 3 i can hear it changing speed.
