DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Measuring the earth rod resistance with an efli tester
Author Message
TONY144
from United Kingdom
PostPosted: Sun Apr 06, 2008 7:18 am Reply with quote
does anyone know please if it is possible to test the value of the earth rod resistance Ra I believe using a 3 lead tester on an efli robin tester because the niceic book and other literature i have seen only shows a 2 lead tester on phase and earth rod ? any suggestions
Back to top
 Alert Moderators
sparkybird
from United Kingdom
Thanked: 36 times
PostPosted: Sun Apr 06, 2008 10:08 am Reply with quote
yes, IIRC look in Guidance Note 3 (testing and inspection) at method 2 for Ra testing.
Someone has nicked my copy or else I'd tell you the page!
SB
Back to top
 Alert Moderators
TONY144
from United Kingdom
PostPosted: Sun Apr 06, 2008 11:30 am Reply with quote
SB
thanks will look
cheers
Tony
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 338 times
PostPosted: Sun Apr 06, 2008 5:15 pm Reply with quote
Back to top
 Alert Moderators
TONY144
from United Kingdom
PostPosted: Sun Apr 06, 2008 9:40 pm Reply with quote
Spark123 wrote:
That will give the ze reading i believe and not the resitance value of the earth electrode but correct me if i am wrong
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 338 times
PostPosted: Mon Apr 07, 2008 4:37 pm Reply with quote
What is the Ze in a TT system?
The black (neutral) is required to power the instrument and in some instances such as DLOC for the electronics to lock the RCD.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 125 times
PostPosted: Mon Apr 07, 2008 7:18 pm Reply with quote
Assuming you measure with main bonding disconnected it is the output imedanace of the suppply transformer plus the impedance of your live supply condutor plus the impedance of your electrode plus the impedance of your suppliers electode.
In practice the impedance of your rod is likely to be much higher than any of the other things mentioned above and it is normal to use the Ze measurement as a conservative estimate of the impedance of your rod.
testing earth rod resistance seperately requires a different type of tester and several temporary test electrodes but there is rarely any reason to do it.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 338 times
PostPosted: Mon Apr 07, 2008 7:26 pm Reply with quote
Yep, what is the difference between a Ze measured with a 3 wire efli tester and a Ze measured with a 2 wire efli tester?
Back to top
 Alert Moderators
TONY144
from United Kingdom
PostPosted: Mon Apr 07, 2008 8:59 pm Reply with quote
Thanks lads between you all i now have the answer to my initial question.
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
lightweight EFLI tester? 20 340 Sun Mar 10, 2013 12:12 am
Measuring the Earth Electroded resistance 25 1360 Fri May 25, 2007 8:22 pm
Measuring earth electrode resistance 3 5320 Fri Nov 02, 2007 9:48 pm
efli and rcd test danger 5 440 Mon Mar 19, 2007 6:41 pm
EFLI Testing 6 681 Sun Apr 22, 2007 7:33 pm
DIYnot
