DIYnot
Local | Network
   DIYnot > Forums
Local | Network
radiator only heats up across the bottom.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
bonsi007
from United Kingdom
PostPosted: Tue Apr 08, 2008 10:16 pm Reply with quote
Hello, I have had a look at other posts to see if this has been covered, but I couldn't find it, if it has , Sorry.
My problem is, all the radiators up stairs only heat up across the bottom, about 20mm high. They are all pretty old, and are single radiators. does anyone know what the problem could be and how do I fix it?? Thanks in advance for your help.
Kind regards
Back to top
 Alert Moderators
robertito
from United Kingdom
PostPosted: Tue Apr 08, 2008 10:22 pm Reply with quote
Have you tried letting the air out of them ?
Back to top
 Alert Moderators
petit_pablo
from United Kingdom
Thanked: 1328 times
PostPosted: Tue Apr 08, 2008 10:24 pm Reply with quote
get yourself a radiator bled key and bled the air out of them
Back to top
 Alert Moderators
bonsi007
from United Kingdom
PostPosted: Wed Apr 09, 2008 11:02 am Reply with quote
thanks for your advice, I have not bleed them yet, I have never done this before (this is my 1st house with central heating) I take it this is a pretty easy job. The problem started when we had our new kitchen extention, and a nwe rad was put in, could this have highlighted the problem?
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 80 times
PostPosted: Wed Apr 09, 2008 11:04 am Reply with quote
Back to top
 Alert Moderators
bonsi007
from United Kingdom
PostPosted: Sat Apr 12, 2008 1:44 pm Reply with quote
Thanks for your help thus far, but I bleed all my rads and still nothing.
I turned the central heating off, opened the valve, air came out, but no water? (the downstairs ones water came out as I expected) I left it for a few minutes, could it be there is just not enough water in my system? is it easy enough to top up?? sorry if these sound like dumb questions, but I am a real newbie with plumbing!!
I have a newish combi boiler fitted, if this makes any difference?
Also, I have sheared off one of the valve screws, are these pretty easy to get hold of??
Thanks Simon
Back to top
 Alert Moderators
twgas
from United Kingdom
Thanked: 424 times
PostPosted: Sat Apr 12, 2008 1:47 pm Reply with quote
should be a filling loop near boiler
gauge on boiler should read 1bar when cold
Back to top
 Alert Moderators
bonsi007
from United Kingdom
PostPosted: Sat Apr 12, 2008 3:26 pm Reply with quote
thanks Mick, I will have a look!
Kind regards
Simon,
Back to top
 Alert Moderators
bonsi007
from United Kingdom
PostPosted: Sat Apr 12, 2008 4:53 pm Reply with quote
I can't seem to find that water pipe, but the pressure is reading 0 bar.
Back to top
 Alert Moderators
GasMan1965
from United Kingdom
PostPosted: Sat Apr 12, 2008 5:06 pm Reply with quote
What boiler is it ??
Some time the filling loop is on the bottom of the boiler ?
Back to top
 Alert Moderators
bonsi007
from United Kingdom
PostPosted: Sat Apr 12, 2008 9:20 pm Reply with quote
Thanks, it was at the botton, I found the instruction manual and got it sorted, as soon as it started to fill up with water, the bar pressure reading went up, so all sorted! thanks for your help..
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Combi boiler system,one radiator only heats up at the bottom 2 460 Mon Feb 07, 2005 7:51 pm
Radiator heats ups when hot water only is on 13 600 Sat Sep 19, 2009 6:04 pm
New Radiator never heats up 28 1340 Mon Nov 08, 2004 4:19 pm
running hot water heats up radiator! 7 1300 Tue Jun 01, 2004 2:04 pm
Radiator heats up at frost setting 3 80 Sun Nov 04, 2012 11:27 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
