DIYnot
Local | Network
   DIYnot > Forums
Local | Network
INSTALLING PUMP ON GRAVITY FED WATER SYSTEM..HELP!!!
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
rsj84
from United Kingdom
PostPosted: Sun Apr 13, 2008 8:25 pm Reply with quote
Hi all...
Im just doing some work on my bathroom and wish to install some new mixer taps on the basin and a shower bath mixer which all require a minimum of 1bar pressure to operate.
I have a gravity fed system which does not do the job...obviously...
I cant raise the cold water storage much more than it is...although I dont think this will do enough to make a difference..
My only option now is to install a pump.. the one im looking at is a Salamander Right RGP40 pump.
I know this will sort out the hot water... but my question is.. will I need to have one for the cold water as well?
Any help would be appreciated regarding installation of the pump... i.e wiring etc..
Back to top
 Alert Moderators
andytheplumber
from United Kingdom
Thanked: 10 times
PostPosted: Sun Apr 13, 2008 9:05 pm Reply with quote
Yes you do.
Back to top
 Alert Moderators
andytheplumber
from United Kingdom
Thanked: 10 times
PostPosted: Sun Apr 13, 2008 9:08 pm Reply with quote
Best place for pump is next to the hot water cylinder, and you need a seperate 13amp spur to feed the pump and lots of isolation valves
Back to top
 Alert Moderators
stardanny
from United Kingdom
Thanked: 195 times
PostPosted: Sun Apr 13, 2008 9:13 pm Reply with quote
rsj84 wrote:
Hi all...
Isn't this for a combi only, main fed?
Dan
Back to top
 Alert Moderators
rsj84
from United Kingdom
PostPosted: Sun Apr 13, 2008 9:21 pm Reply with quote
thanks for the replies..
does that mean i would need 2 separate pumps... or is there one that can do both?
with regards to the wiring... if the pump is placed near the hot cylinder.. i have the wiring for the whole central heating/hot water system there... can the wiring be taken from there... or would i have to spur from the main sockets?
andytheplumber...just a random question.. how much would you charge for such a job? icon_rolleyes.gif
Back to top
 Alert Moderators
rsj84
from United Kingdom
PostPosted: Sun Apr 13, 2008 9:25 pm Reply with quote
the taps that im looking at are suitable for gravity fed system... but need a minimum of 1bar pressure...
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Installing a Shower Pump to an existing Gravity Fed Shower 5 34640 Fri Oct 12, 2007 10:24 am
putting a pump in gravity water system HELP 6 1160 Sun May 08, 2005 3:37 pm
adding a pump to gravity hot water system 2 440 Mon Apr 19, 2010 3:42 pm
Will a system work partially on gravity with faulty pump 2 520 Sun Nov 27, 2005 5:18 pm
pump whole house, gravity system 2 40 Wed May 02, 2012 6:56 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
