| Author |
Message |
davegrange65
Joined: 16 Apr 2008 Posts: 2 Location: Lincolnshire, United Kingdom
Posted: Wed Apr 16, 2008 8:56 am |
Can anyone tell me how the dt10rf timer actually works? I can set the start times for the first 'period' but am not sure what triggers the subsequent start times. Any help would be appreciated! |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
chris1973swinton
Joined: 15 Apr 2008 Posts: 5 Location: Lancashire, United Kingdom
Posted: Wed Apr 16, 2008 8:00 pm |
| Back to top |
Corgigrouch
Joined: 13 Dec 2007 Posts: 2482 Location: United Kingdom Thanked: 167 times
Posted: Wed Apr 16, 2008 8:29 pm |
The DT10RF is a little awkward to use but it has four time zones in which you set the temperature at which you want the room to be at.. Example first time zone you may want your house to be at 21c, then later you may want it to reduce to 17c, etc... The heating is never off, but will not run until the stat calls for heat. |
| Back to top |
mikej2005
Joined: 14 Aug 2005 Posts: 323 Location: Cheshire, United Kingdom Thanked: 8 times
Posted: Wed Apr 16, 2008 11:41 pm |
I've got a Mk1 DT10RF fitted to my WB combi, so if you have a Mk1...
Divide your day into 3 zones - typically morning (Zone 1), daytime (Zone 2) and evening (Zone 3). Pick a time at which each 'zone' will start.
The 4th zone is esentially night-time and is denoted with a moon symbol.
Decide what temperatures you want for each zone. If you don't want the heating on at all in any particular zone (eg. night-time), then chose a figure low enough so that the stat won't call for heat.
Another important thing to note - it's an Optimiser stat, which means you need to set the initial time for Zone 1 to be 1 hour before you wish the house to be at your chosen temperature.
Eg. If you want it to be 20oC at 7am when you get up in the morning, then set the initial time for Zone 1 to 6am. The stat then learns how long it takes your house to heat up and will eventually learn to come on as late as possible during that hour, potentially saving energy. |
| Back to top |
davegrange65
Posted: Sat Apr 19, 2008 7:37 am |
Many thanks for your help everyone. |
| Back to top |
Ltnman
Joined: 16 Apr 2008 Posts: 118 Location: Bedfordshire, United Kingdom Thanked: 1 time
Posted: Thu Apr 24, 2008 5:27 pm |
It actually has 6 time zones but only a 24 hour timer while the Optimiser can be set up on a per day basis. |
| Back to top |
John0071
Joined: 16 Jan 2010 Posts: 2 Location: Surrey, United Kingdom
Posted: Sat Jan 16, 2010 10:38 am |
| davegrange65 wrote: | Hi,
Each Start and stop time is an "Event" so you have to say when you want a temp to start and when you want it to stop. |
| Back to top |
janethuyton
Joined: 02 Oct 2012 Posts: 1 Location: Lancashire, United Kingdom
| Back to top |
sherbert
Joined: 13 Jul 2007 Posts: 318 Location: Sussex, United Kingdom Thanked: 52 times
Posted: Tue Oct 02, 2012 8:04 pm |
to turn it off so that there is no heating and hot water only ...... hold the +&- button down together for 8 seconds and hey presto it should say off .. just press any button to override this
As has been said ........ there are no off times on this timer .. All you are doing is setting what time the boiler will look for a set temp
for example
06.30 - 21c .. at 06.30 it will look for 21 c
08.30 - 17c ... at 08.30 it will not come on unless lower than 17c
etc etc |
| Back to top |
