Joined: 22 Apr 2008 Posts: 4 Location: Gloucestershire, United Kingdom Thanked: 0 times
Posted: Tue Apr 22, 2008 2:53 pm Post Subject:
Cooker hood install
hi all, i want to install a cooker hood in my kitchen, my intention is to install a switched fused spur coming off the ring main - which i will have to connect into above the kitchen ceiling (presumably via junction box - adhering to appropriate access via upstairs floorboards and labelling of junction box locations etc) and running the cable from there down stairs through two chases in the wall (one vertical going to switched spur from ring main, the other being fed from switched spur and running horizontally to an unswitched socket which will be mounted behind cooker hood - cable runs adhering to safe zones). Does this sound feasible/safe - i take it that it is also notifiable ? Any help would be appreciated.
Joined: 27 Jul 2006 Posts: 6518 Location: Oxfordshire, United Kingdom Thanked: 218 times
Posted: Tue Apr 22, 2008 3:07 pm Post Subject:
Sounds feasible. Do not hide a socket behind the cooker hood. Just use a 5A junction box to join the cable from the fan to the cable from the FCU. There is a fuse in the FCU that you can get at, you wont be able to access the socket if the fuse goes in the plug behind the cooker hood.
Whether its safe or not will depend on your level of competence.
All electrical work in a kitchen is notifiable.
__________________ TTC
Electricity is really just organized lightning - George Carlin
Posted: Tue Apr 22, 2008 3:15 pm Post Subject:
cheers guys. unfortunately, i have already sunk a back box into the wall for the unswitched socket - obvioulsy nothing connected up/live at the mo. instead of junction box could i use appropriately rated con-block inside back box and cut hole/grommet in blank plate ?
As you can see am not a sparky - deal with Audio Visual/IT kit that starts at the the plug socket
Posted: Tue Apr 22, 2008 3:53 pm Post Subject:
If you decide to DIY it then the LABC will want to see your wiring before you plaster over it. Note that there will be a charge from them. Call them up and find out how much it will be.
Then get quotes from registered sparks
You can then decide which way to go - DIY or have a spark do it who can notifiy the works as part of his service to you.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
