i have searched goggle and the forum but didn't find what im after.
i ama bout to replace with upvc windows. LABC will be inspecting but i am currently held back becuase the person who does the money stuff aint at work , so i can't send the forms in.
i know that the existing windows have a brick reveal and have a vdpm inbetwen the brick and blocks. Im not sure if this is cut off level with the window frame or if it has been brought through to the inside of the house then cut off under the plaster, will this make a difference? or is it just a matter and fitting new frame.
second question is regarding fixings. i was going to use them fixings by powerline that have the t30 star drive. you just drill a 6mm hole and screw into brick. will these be ok into brick? or is there something better.
also what lenght should i be looking to get into the brick work? frame will take approx 30mm of screw up, is 50mm in brick enough?
thanks
thanks
