The frame is an external frame (now indoors) measuring 78x30. We would like to fit a bifold door - but could use a std glazed door if too many issues. The issues are :-
1-original door was thicker than new door by 10mm ish- will have a gap between door and stops on frame. How to get round this.
2-I read that if you fit a bifold door, you have to remove the door stops - but they seem to be part of the frame. Not a small baton which could be prised off. Cant really see why I need to remove stops if the bifold opens the same way as original door.
Any help on above appreciated!
