DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hotpoint WD420 - Flashing lights
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
samgoffe
from United Kingdom
PostPosted: Tue Jun 17, 2008 6:45 pm Reply with quote
My hotpoint WD420 goes through washing fine but when it comes to drying it, 3 lights will flast.
The power flashes quickly, the other 2 flash slower. (machines off so cant see whats flashing)
The washing is soaked with hot water.
I've had the filter out of the back and it was bad, but the problems still happening.
Any ideas?
Back to top
 Alert Moderators
rocks1
from Unknown or unspecified country
Thanked: 1003 times
PostPosted: Tue Jun 17, 2008 6:59 pm Reply with quote
need to know wot other 2 lights are flashing , it is a error code icon_lol.gif
Back to top
 Alert Moderators
samgoffe
from United Kingdom
PostPosted: Tue Jun 17, 2008 8:15 pm Reply with quote
will find out and post. think its "drying high heat" and "rinse hold"
Back to top
 Alert Moderators
rocks1
Thanked: 1003 times
PostPosted: Tue Jun 17, 2008 9:10 pm Reply with quote
let us know is it 1 and 2 2 and 4 1 and 3 etc
Back to top
 Alert Moderators
samgoffe
from United Kingdom
PostPosted: Wed Jun 18, 2008 7:54 am Reply with quote
1 and 3.
Back to top
 Alert Moderators
rocks1
Thanked: 1003 times
PostPosted: Wed Jun 18, 2008 2:33 pm Reply with quote
that fault code is f 10 check filter for any blockage also blow down presure tube .after that check that module conection are pushed on and are not loose
Back to top
 Alert Moderators
samgoffe
from United Kingdom
PostPosted: Wed Jun 18, 2008 2:53 pm Reply with quote
thanks.
I am playing with it tonight, i've seen else where about the connections.
Will update if i fix!
Back to top
 Alert Moderators
samgoffe
from United Kingdom
PostPosted: Sun Jun 22, 2008 1:24 pm Reply with quote
Had a play with it, and made sure all the connectors were ok.
Its doing the same thing as before, but the lights are different to what i thought.
The lights flashing are...
Reduce creases and Time saver (2 & 4)
What do these mean?
Thanks.
Back to top
 Alert Moderators
rocks1
Thanked: 1003 times
PostPosted: Sun Jun 22, 2008 3:36 pm Reply with quote
2 and 4 mean fo5 check filter assy time out draining access is at the back down the bottom.remove white cover .also check if drain hose is connected to sink spigot not blocked
Back to top
 Alert Moderators
samgoffe
from United Kingdom
PostPosted: Sun Jun 22, 2008 4:30 pm Reply with quote
Thanks.
Filter has been out already. and cleaned.
i suppose the pipe could be blocked. will see if i can take a look.
Back to top
 Alert Moderators
samgoffe
from United Kingdom
PostPosted: Sat Jun 28, 2008 4:23 pm Reply with quote
Right, so the dryer doesnt seem to work still. although we've not used it for a week.
But not clothes are smelling when they come out. Any ideas?
Back to top
 Alert Moderators
samgoffe
from United Kingdom
PostPosted: Fri Jul 25, 2008 9:10 am Reply with quote
Any help?
clothes still smelling a bit.
on the upside, my girlfriend doesnt want to use the dryer incase it breaks again. So were saving money!
Back to top
 Alert Moderators
diyignoramus
from United Kingdom
PostPosted: Mon Dec 20, 2010 7:03 pm Reply with quote
I have this error, lights 1 & 3 flashing, can anyone please tell me how to find the filter, the pressure tube & the module connection?
Back to top
 Alert Moderators
rocks1
Thanked: 1003 times
PostPosted: Mon Dec 20, 2010 7:09 pm Reply with quote
Remove rear White cover , filter is the big black cup in front pcb in the corner , presure tube connected to sump runs to the top left hand side under the dispenser.
Back to top
The following user says thank you to rocks1 for this useful post:
diyignoramus (21 Dec 2010)
 Alert Moderators
Quaker
from United Kingdom
PostPosted: Tue Dec 28, 2010 12:04 pm Reply with quote
Hi, having worked through the very helpful error codes list I've concluded that I have a F09 fault (eprom/setup error) does anyone have any ideas how I can fix it!!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
hotpoint wd420 flashing lights 12 720 Fri Jul 16, 2010 8:36 pm
Hotpoint Washing Machine WD420 - Flashing Error Lights 4 3800 Wed Jun 17, 2009 9:41 am
Hotpoint WD420 flashing lights 4 140 Fri Sep 23, 2011 6:54 pm
Hotpoint Aquarius WD420 All Lights Flashing 2 340 Sat Feb 07, 2009 11:25 am
Hotpoint WD420 Lights Flashing / Won't Spin 3 1640 Mon Apr 26, 2010 2:47 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
