DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Tumble-Dryer hose hole
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
mikedmc
from United Kingdom
PostPosted: Tue Jul 01, 2008 11:14 am Reply with quote
I need to put a hole in the wall for the tumble-dryer hose. I haven't got the hole cutting kits. I do have an SDS drill and long drill bits so was thinking of drilling the centre of the hole and then drilling a series of holes round the diameter of the hole and knocking it out. Messy but I will try and tidy it as best I can and it will be covered by vent outside and behind the tumble-dryer inside. Sound ok or is there a better solution? Tips?
Thank you.
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 221 times
PostPosted: Tue Jul 01, 2008 11:26 am Reply with quote
I assume you will be fitting the outside vent cowl thing what ever its called, this will cover the mess you will make.
I used hammer & cold chisel
Back to top
 Alert Moderators
mikedmc
from United Kingdom
PostPosted: Tue Jul 01, 2008 12:30 pm Reply with quote
So i'm good to go then. Lovely. Ty.
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2603 times
PostPosted: Tue Jul 01, 2008 12:39 pm Reply with quote
Drill from both sides if you can - this will minimise breakout. Expect to cement round the pipe end if you want to fit the louvred grille with screws. Failing that, use silicone to stick it on. Cheers John icon_smile.gif
Back to top
 Alert Moderators
mikedmc
from United Kingdom
PostPosted: Tue Jul 01, 2008 1:44 pm Reply with quote
Just what I was thinking, once I have the initial centre hole done I will mark out the diameter of the hole and drill from either side.
Cheers.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1500 times
PostPosted: Tue Jul 01, 2008 1:55 pm Reply with quote
the core drills are so much easier and neater, see what it would cost to hire one for half a day locally.
btw I wouldn't use the louvred vents like venetian blinds, thery rattle annoyingly and break of in string winds
these cowl vents have a backdraught flap inside, i prefer them
Back to top
 Alert Moderators
mikedmc
from United Kingdom
PostPosted: Tue Jul 01, 2008 3:00 pm Reply with quote
Cheers John,
Never seen them vents before. Can you get them in B & Q, Wickes etc. or links to them? Ideally somewhere where I can have it for tomorrow so I can fit it all. Ty.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1500 times
PostPosted: Tue Jul 01, 2008 7:30 pm Reply with quote
that pic came from Screwfix but i think i have seen them in various DIY sheds. Colours vary.
Back to top
 Alert Moderators
mikedmc
from United Kingdom
PostPosted: Mon Jul 07, 2008 10:45 pm Reply with quote
Thank you for all the help and advice. Drilled the hole out as original post and it worked a treat. Although for future reference I will make the hole a little larger.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
first bit of DIY I've done in new home... hose reel! 2 401 Tue Jun 30, 2009 8:10 am
garden tap/hose has poor flow? 2 380 Tue Mar 18, 2003 9:17 am
garden tap/hose has poor flow? 4 640 Tue Mar 18, 2003 9:08 am
Tumble dryer vent 4 1320 Sun May 22, 2005 3:18 pm
Best place to core drill tumble dryer vent 5 160 Fri Aug 22, 2014 9:09 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
