DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
wiring inside fibreglass insulated walls/ceilings
This topic originated from the How to page called Preparing cable for connection
Click here to return to the page called Preparing cable for connection.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
Quadroclops
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 16, 2002 12:21 am    Post Subject:
Reply with quote Thanks
I see I shouldn't route my wiring (especially the 10mm for the shower) inside insulation -I was planning to clip it inside a cavity wall with fibreglass insulation) -I've just had the loft insulated & they've put a carpet of thick fibreglass all over the wiring. Now this is common practice I know -does anyone want to comment?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Guest
Thanked: 0 times
PostPosted: Tue Dec 17, 2002 1:14 am    Post Subject:
Re: wiring inside fibreglass insulated walls/ceilings
Your right, cabling shouldnt be routed within insulation unless the cable/circuit has been designed using "correction factors". These factors take into account the fact that a cable of size x cannot carry as much current without overheating in insulation as apposed to being in free air. Obviously cooker/shower/socket cables are more at risk in general than lighting circuits.
The best idea for the diy'er is to avoid running cables in insulation. As for the people who have insulated your loft, they obviously do not appreciate these facts.
Back to top
 Alert Moderators
Quadroclops
from United Kingdom
Thanked: 0 times
PostPosted: Wed Dec 18, 2002 4:08 am    Post Subject:
What a smart uh...boy am I! Better than setting fire to my house tho' -not to mention my hard work... does anone know how to calculate the correction factors -or it about right to just double the cable size? This is just for the lighting wire in a flat-roofed bathroom -it's freezing in there, so I'm keen to insulate.
[Edited by Quadroclops on 18-12-2002 at 4:12 AM GMT]
[Edited by Quadroclops on 18-12-2002 at 8:12 AM GMT]
Back to top
 Alert Moderators
Guest
Thanked: 0 times
PostPosted: Thu Dec 19, 2002 1:32 pm    Post Subject:
I know it's a boring answer but if you really want to know try 'The electriciens guide to the IEE wiring regs' ISBN 0-9517362-9-9 by John Whitfield.
Doubling the cable size is probably overkill - 20mm cable for a shower? That's bigger than the main incomer in many older houses.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Epoxy resin and fibreglass resin? 10 460 Tue Aug 04, 2009 12:57 pm
Chipped fibreglass bath 3 980 Wed Jul 27, 2005 12:46 pm
Chipped acrylic (or fibreglass) bath HELP! 5 1300 Mon Feb 25, 2008 10:46 pm
Why does the inside of my kitchen cupboards smell of damp? 3 1400 Thu Jan 03, 2008 11:31 pm
Fitting extractor vent from inside 2 1380 Tue Aug 28, 2007 9:45 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
