Greggers,
you are talking b*****s, stoppit now.
There are a number of different finishes to repointed brick work, the finish will depend on the existing.
what is important is to establish if in fact the brickwork needs repointing at all.
If it does, the main problem is to get someone to dig out the existing perished joints to 20mm.(as a minimum)
and then to make a tidy job of repointing the wall.
Trust me, I'm a bricky.
as i havent see the wall in question i for 1 dont know what type of pointing is required and nor do you,the OP has said it needs repointing.
and yes im pretty certain he understands that the old pointing needs to be removed, and i will continue to use the term BUCKET HANDLE just to wind you lot up iirc to strike a weathered joint you use a dutchman?or is it a frenchman?
if the op thinks its too much for him to tackle,thats why i said get a brickie in,if he thinks he can take the job on himself then fairplay to him thats why hes here on a diy forum trying to get as much info as possible.
lets face it taking your time anyone can make a good job out of pointing and laying bricks but carpentry is an art.
