Digital room thermostats...
3 Sep 2008
London
Hi
I am thinking about changing my room stat to a new modern look programmable digi room stat!
is the wiring the same.. ie. 3 wires, common, call and sat?
i have looked at a few sites, drayton, etc to look at what's available.
any recommendations from personal preference?
also one of the spec's i read about room stats (DRAYTON) said "battery powered" : does this mean the lcd digital display is battery powered? i guess it's still powered (via the wiring centre) the same way as normal room stats are, hence the 3 wires also...
hi - yes programmable room stats are operated by a battery and usually installed/replaced in the same way as a normal room stat (ie 3 wires, common, call and sat (1, 2 & 3 usually).
when you get one make sure you check the instructions re wiring, they often dont use a neutral.
twgas is right-if your old room stat uses a neutral then remove this (also from the junction box end as well as the room stat end). you just need the 3 wires, common, call and sat.
Mechanical stats had: Live, Neutral, Switched Live(call) the Sat terminal was rarely used. Digital stats only need a live and switched live as the neutral is no longer required.
Honeywell CM900 series
There are two types of boilers: 1. those which get their 240v supply voltage via the thermostat; 2. Those which have an independent 240v supply and have a pair of "volt free" terminals to which the programmer/thermostat is connected.
Most programmers can handle both types of boiler; just make sure which type you need before you buy.
Many digital programmers use a battery to run the internal electronics and display.
There are several possibilities:
  • Mains run programmer - switched 240v to boiler: needs 3 wires (+ earth)
    Mains run programmer - volt free boiler: needs 4 wires (+ earth)
    Battery run programmer - switched 240v to boiler (needs 2 wires)
    Battery run programmer - volt free switching to boiler (needs 2 wires)
the DRAYTON room stat (digi) i have has HTG SAT, HTG CALL and COM terminal's (3) in total. The NEUTRAL is not required.
If your old room stat has 3 terminals (probably common, call and sat, then you may need a multimeter to make sure the swap the correct wires!!
not many systems use a "sat" on room stat, third wire is more likely a neutral.
hi thanks all for your responses
i am slightly confused now! ...
my room stat currently has 3 terminals, i believe them to be common, call and satisfied.
if the new room stat has 3 terminals these obviously just need swapping over (will the new room stat have instructions for this to make it clearer)?
secondly, if my original room stat DOES have 4 terminals as D_Hailsham stated - what do I do with the NEUTRAL terminal that does not need to be used for a digi room stat? do i just ignore it ??
Thanks.
What make/model is you existing stat?
Which terminals have wires connected to them?
Not necessarily correct. If one of the wires is a neutral and the new stat is battery operated, the neutral will not be required and should be disconnected at both ends and cut short. (Don't assume that a blue wire is necessarily a neutral)[/quote]
Easiest solution
Buy a new programmer
Post info about your old stat, your new stat and your boiler.
Someone will tell you what to do ;)
