DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
new socket
This topic originated from the How to page called Adding a spur to a ring circuit from a socket
Click here to return to the page called Adding a spur to a ring circuit from a socket.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
lina
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 11, 2004 10:31 am    Post Subject:
new socket
Reply with quote Thanks
I need to install a socket where the fuse box is, there are no other existing sockets nearby. How do i do this? Thanks.
________________________________
Moderator
Moved as originally posted in WRONG FORUM (general diy)
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
2scoops0406
from United Kingdom
Thanked: 1 time
PostPosted: Mon Oct 11, 2004 2:59 pm    Post Subject:
You need to either :-
Take a spur off an existing socket, even if it's not near.
Extend and existing ring, even if it's not near.
If you have suitable room in the fuse box, create a new circuit.
However, personally I wouldn't advise any of the above, I think you're best off calling an electrician. Do NOT play around with the fuse box, there is a very real possibility of receiving a fatal shock from this.
Good Luck, most of all be careful !!
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Mon Oct 11, 2004 5:33 pm    Post Subject:
Re: new socket
Lina - how accessible are the cables leaving the CU, and where, in relation to those, do you want the socket?
I'm just wondering if it would be an easy job to insert the new socket at the start of one of the rings.
I'm also a little worried that you thought you needed a socket nearby to be able to add a new one....
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Mon Oct 11, 2004 5:36 pm    Post Subject:
btw CU is the modern term for fuse box
your options are
1: put the socket on its own 15A/16A fuse/breaker
2: add a third 2.5mm cable to the breaker that is powering a ring and run it direct to a socket
3: disconnecty a ring cable from its breaker connect it to your new socket and then
option 1 is prefered if you have a spare breaker space in the CU
oprion 2 is probablly neater than option 3 as rerouting existing cables tend to get messy but option 3 may be easier if your CU has low terminal capacity.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Mon Oct 11, 2004 5:37 pm    Post Subject:
btw a picture of your CU would be very helpfull
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Mon Oct 11, 2004 5:44 pm    Post Subject:
adding cuircuits to a CU really isn't that hard and is something we commonly give diyers advice on here
afaict only the following are considered as things we shouldn't advise diyers to do
1: pull the service fuse
2: work on 3 phase
3: work on commercial stuff
Back to top
 Alert Moderators
ZenStalinist
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 11, 2004 7:23 pm    Post Subject:
And what about industrial stuff ...
Some three phase is okay for DIYers IMO, such as connecting a three phase oven - just very basic stuff like that... anything involving the DB is out though.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Mon Oct 11, 2004 7:28 pm    Post Subject:
mmm from the pics i have seen of modern 3 phase DBs they don't look any harder to add a cuircuit to than a CU
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 1 time
PostPosted: Mon Oct 11, 2004 9:43 pm    Post Subject:
2: work on 3 phase
I'm hijacking the post here, but working from the CU, without pulling the REC fuse, is effectively working live no? I'm absolutley more than happy to be quoted as wrong, but I'd rather be safe than sorry. icon_smile.gif
Back to top
 Alert Moderators
Damocles
from United Kingdom
Thanked: 0 times
PostPosted: Mon Oct 11, 2004 10:05 pm    Post Subject:
The CU has a big switch which turns off power to all metalwork exposed inside. Assuming the sparks who installed it cut the insulation on the meter tails properly, then everything else should be safe to proceed with caution.
Even with the switch 'on' the busbar and all live parts before the mcbs should be at least partially shielded by plastic bits when the main cover is off.
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 1 time
PostPosted: Tue Oct 12, 2004 12:48 pm    Post Subject:
Yeah, agreed, that's where my situation and possibly others situations break down. If I 'm working on a circuit, then it is preferable to isolate only the circuit in question. Trouble is, some of the old cartridges in my Fuse box are broken, effectivley exposing the busbar, which I assume is capable of giving me, an 80A jump. Yes I know that the old FB must be replaced, as it is potentially dangerous, even though it is protected with a downstream RCU.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Oct 12, 2004 3:36 pm    Post Subject:
Oh a lot more than that. Not that it matters, dead is dead.
But you shouldn't assume that everybody else's CU is in such a parlous state.
Indeed it must, and sooner rather than later!
Don't know what an RCU is, but if it's downstream it won't be protecting the CU...
__________________
Back to top
 Alert Moderators
pipme
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 13, 2004 4:30 am    Post Subject:
Regional Co-ordination Unit ? ... Downriver from incomer or Cu .. Only Edward knows ... but then again ???
P
__________________
Beware of little expenses; a small leak will sink a great ship. (Ben Franklin)
Back to top
 Alert Moderators
Damocles
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 13, 2004 8:18 am    Post Subject:
Do you mean there is a RCD between meter and fusebox? then presumably you could turn it off.
If there is an RCD before the fusebox, then it might protect you from shock if you touched something you would have sooner not.
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 1 time
PostPosted: Wed Oct 13, 2004 12:58 pm    Post Subject:
RCU??? what am I like?? sorry, RCD !! Yes it will stop me from getting a probably fatal bolt off the fuse box, that is if it works (which it seems to) but that is not the issue, if it doesn't work then accepted, I'm toast !! I have the quotes for a replacement coming in as I type. The old box, is knackered, old, dangerous, and has to go.
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
installing an exta socket 2 160 Thu Feb 21, 2008 7:43 pm
Buzzing RCD Socket 8 260 Tue Feb 19, 2008 11:27 pm
Double socket above radiator 4 280 Sat Feb 23, 2008 3:18 pm
13a socket under bath 4 280 Sun Feb 24, 2008 8:50 pm
fused spur with socket 9 520 Fri Feb 29, 2008 10:05 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
