Worcester 24i RSF-L Combi boiler problem:
When I turn the hot water tap on the boiler fires up and hot water is dispensed from the tap. However after a minute or two the water goes cold. Is this a diverter valve problem? The boiler also makes a noise after I have turned the tap off that sounds like it is trying to fire up / reset or something, but it can't make its mind up. The heating function of the boiler works fine. Can anyone please advise.
Thank you.
Thank you.
