Hello peeps
Is it okay to switch the live wire of a 2.5mm tc+e on the mains circuit using a standard light switch?
Does the difference in connector block and junction box maximum amp rating only apply due to the size of the cables not fitting with smaller connector blocks or are less rated connectors actually not able to handle higher currents (i.e. overheat)?
What are the connector block current rating req's for 1mm, 1.5mm and 2.5mm tc+e please?
Thanks very much in advance
