DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Replacing Accenta 8ep219 alarm keypad
Post new topic   Reply to topic    DIYnot.com Forum Index > Alarms, CCTV & Telephones
Author Message
Evo1962
from United Kingdom
PostPosted: Thu Oct 16, 2008 11:59 am Reply with quote
I have recently had to replace my accenta 8ep219 alarm keypad which i broke whilst decorating. On checking I found that the model had been discontinued and replaced by the accenta 8ep416. Thinking it would be straight forward, I ordered the replacement and wired it up making a careful note of where the 6 wires went.
Guess what? completely dead nothing at all. can anyone help
Back to top
 Alert Moderators
Denford
from United Kingdom
PostPosted: Thu Oct 16, 2008 12:11 pm Reply with quote
You may have blown the separate fuse that supplies the remote keypad.This is in the main panel and is usually 1 amp 20mm type.
Back to top
 Alert Moderators
Evo1962
from United Kingdom
PostPosted: Thu Oct 30, 2008 2:37 pm Reply with quote
I have replaced Fuse for the keypad, still nothing, anymore suggestions woud be appreciated before i get someone in and it starts costing
Back to top
 Alert Moderators
dirkdangler
from United Kingdom
PostPosted: Thu Oct 30, 2008 4:16 pm Reply with quote
see when you changed the keypad did you try and press a button? ive changed a few off these keypads before with the system still working, and when its changed it looks totally dead. then i press a button and it comes to life. failing that its either wired wrong or fuse blown. you could also check the wiring in the main panel to see if you have the correct colours at the keypad end.
Back to top
 Alert Moderators
Evo1962
from United Kingdom
PostPosted: Thu Oct 30, 2008 4:22 pm Reply with quote
yes I have tried pressing the buttons, nothing. The keypad was a direct replacement for the one I had damaged and was wired the same way so I am confident that is ok. I have replaced the fuse in the main box for the keypad.
Back to top
 Alert Moderators
dirkdangler
from United Kingdom
PostPosted: Thu Oct 30, 2008 4:26 pm Reply with quote
have you tried wiring your old keypad back on to see if that works? cause if it does new pad must be faulty
Back to top
 Alert Moderators
Evo1962
from United Kingdom
PostPosted: Thu Oct 30, 2008 4:34 pm Reply with quote
The alarm was working perfectly well until I decided to decorate, during this I damaged the keypad, thus I am unable to refit it. Thanks for your efforts.
Back to top
 Alert Moderators
dirkdangler
from United Kingdom
PostPosted: Thu Oct 30, 2008 4:45 pm Reply with quote
its gotta be faulty then. i know the system and it is a replacement so it should work when fitted.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 30 times
PostPosted: Thu Oct 30, 2008 7:48 pm Reply with quote
bet it isnt.
its not that often you get a bot of brand new kit and its F
often people say , this is faulty, that is faulty, you go and look and they have wired it wrong, or overlooked something.
i would check for a voltage at the keypad
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Alarms, CCTV & Telephones All times are GMT
Page 1 of 1
Jump to:
Replacing Alarm keypad (Accenta ) 7 240 Thu Nov 28, 2013 9:54 am
Replacing Keypad on an old Securit 700L system 12 260 Mon Jan 26, 2015 2:49 pm
Replacing TS700 keypad - what with? 3 100 Wed Jan 12, 2011 1:16 pm
Scantronic 9827 keypad issue after replacing 9800 keypad 10 200 Mon Mar 24, 2014 9:45 pm
Replacing Eurosec CP8L keypad 19 960 Sat Nov 03, 2012 11:31 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
