Replacement double glazing windows - What thickness?
19 Mar 2007
Belfast
Hello we have 1st generation double glazing with a 6mm gap between panes. Is there a good heat insulation window technology that would retain the frames at 6mm, or will i just have to replace the lot and go for a 12mm gap instead?
You can get coated glass and argon gas fill, but the extra cost may be more than just replacing the existing frames - which are likely to be thermally inefficient too.
