Preventing door from swinging in the wind.
9 Aug 2006
Lancashire
I need to find a way of preventing the access door on our new bi-fold alu doors from swinging open in wind and damaging itself on the sides of the reveal, then swinging back and slamming, causing Grandma to have a heart attack.
The simplest solution would be to fit buffers at frame level on the reveal, but these won't stop it swinging. What I really need is a braced doorstop, which can be attached to the reveal, bracing itself on the wall, which will both absorb the energy of a swinging door and then capture it until somebody releases a catch.
I have looked at the catalogue of SDS in London but can't see anything that will suit an alu door frame with a complex system of rubber seals.
Any ideas? I thought of getting an engineering firm to weld up a braced bracket in SS or powder coated steel or alu then fit it with a buffer and a standard catch.
have you considered a friction restrictor ? don't know much about aluminium but if the door has a eurogroove (on the top) it may be possible.
Are they bi-fold (concertina) or french doors? if bi-fold they shoudl be restricted anyway?
roger
Hi Rigidraider, did you or anyone on this thread find a solution?
We have the same issue with the access door on Ali bi fold doors!
I wonder whether foot operated spring/hydraulic door holders could be fitted? Companies like Hafele do a full range of these...pinenot :)
