New Cooker
30 Dec 2002
I am in the process of replacing my single built in cooker, to a double built in.
The single oven is plugged into it's own wall socket via a plug, will I be able to plug in my new double as i do not have a cooker circuit?
If so what is the max wattage my new cooker can be to plug in?
The maximun size of anything you can run from a plug is 3KW (3000W) or 13A, the size of a normal kettle or electric fire. Your new cooker should have a plate on it telling you the wattage or maximum current rating.
