DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Brown stains appearing on bedroom wall
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
LTFan
from United Kingdom
PostPosted: Wed Oct 29, 2008 2:09 am Reply with quote
Hi guys,
Hope you can help me suss out what's going on here. About 3 years ago we had our bedroom walls skimmed, we painted, no apparent problems. As of a few months back we noticed brown spots starting to appear on one of the walls. We're in a first floor flat, it's the wall between us and the outside world ( icon_biggrin.gif ), I believe it at one point long ago must have been a fireplace. We painted the plaster first of all with a good coat of white emulsion, then with a bog standard BQ interior matt.
The stains are light brown, range in size from several smaller ones 2" x 2" to a larger fainter stain around 6" x 10", they won't wipe off, there's no particulate matter on the surface. Any ideas what this is and the best way to go about getting shot of it?
Incidently, prior to the skimming the walls were papered, I removed the paper and don't recall seeing anything amiss on the plaster underneath.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1508 times
PostPosted: Wed Oct 29, 2008 4:12 pm Reply with quote
is there a chimney on the other side of this wall?
Back to top
 Alert Moderators
LTFan
from United Kingdom
PostPosted: Wed Oct 29, 2008 11:34 pm Reply with quote
I believe there is a chimney yes, although it's been out of use since before we bought the place some 15 years or so ago. As I said above, there were no similar marks on the original plaster, however there was the dreaded woodchip on top so that might have prevented a similar issue before.
Thanks again for the help.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1508 times
PostPosted: Thu Oct 30, 2008 11:54 am Reply with quote
it is likely that there is damp in the chimney and it is bringing soot-stains as it soaks through the wall. Once this happens it is very difficult to stop and you will have to use a stain blocker.
You also need to get that chimney ventilated, and make sure it is not allowing much rain in through the top or by bad brickwork.
If the old fireplace is in your room you can make a hole where it was bricked up and put in an airbrick. There may be more than one flue in the chimney (e.g. one from upstairs fireplace and one from downstairs fireplace) and they both need ventilating.
As well as the stains, this will also stop damp.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
Denzo tape "stuff" appearing through wall 4 120 Sun Nov 25, 2012 2:22 pm
water stain appearing on wall 5 720 Sat Dec 30, 2006 8:39 pm
Cracks appearing in paint. Is plaster sealer the answer? 3 940 Sun Oct 15, 2006 1:10 pm
Holes appearing in old chimney breast brickwork. 4 280 Thu Jul 15, 2010 3:33 pm
Strange paint marks appearing on ceiling.... 10 120 Mon Oct 10, 2011 8:57 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
