DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Hot Water Booster Pump
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
helensmith1
from United Kingdom
PostPosted: Sun Nov 02, 2008 6:19 am Reply with quote
Hi Guys
just a quick question for your expert eyes please
when fitting a hot water booster pump does it go on the run between the cold water header tank and the immersion tank or the run from the immersion tank to the taps.
Just to avoid the debate there is no way the cold water tank can be raised as we have a flat roof (if only)
the pump is an Grundfos UPA 90
Back to top
 Alert Moderators
Norcon
from United Kingdom
Thanked: 198 times
PostPosted: Sun Nov 02, 2008 10:57 am Reply with quote
Between the immersion tank and the taps. They advise a minimum 2 m head. A surrey flange would be advisable also.
You can get kits fitted without too much disruption which will convert your cylinder over to mains pressure and you can retain the gravity supply to the rest of the home.
A lot of plumbers (ccc's /cc'c presumably) connect mains up to bathrooms when they are fitting a gravity system which I cannot quite fathom why they do so which can create a lot of problems. (some people probably like the thought of mains water for brushing their teeth)
Back to top
 Alert Moderators
muggles
from United Kingdom
Thanked: 517 times
PostPosted: Sun Nov 02, 2008 11:07 am Reply with quote
Between the cylinder and the taps, use a surrey flange to connect. That's not a great pump though so don't expect fantastic results, it'll only increase pressure by a max of 0.75bar
Back to top
 Alert Moderators
helensmith1
from United Kingdom
PostPosted: Sun Nov 02, 2008 7:36 pm Reply with quote
thanks Muggles & Norcon
its been a long miserable weekend, the plumber put the pump between the feed tank tank & hot water tank yesterday, couln't get the pump to switch to automatic and left it on manualy, oh this is after he orginally put it on up side down, so when I got home last night it was red hot, so turned it off at the mains,
Got him back to day to shift the pump between the tank and taps, and now the sensor unit is not working, he says it must be a faulty pump and to send it back.....obviously can't do that because I don't think it was installed properly.
However you said this pump was not up to much by way of increasing hot water pressure, what would you recommend in its place,
as for the plumber yes he is qualified and Corgi reg...but unfortunately a relative so I can't kick his a....
Back to top
 Alert Moderators
Norcon
from United Kingdom
Thanked: 198 times
PostPosted: Sun Nov 02, 2008 9:04 pm Reply with quote
There's a vast array of booster pumps on the market for various applications within the home.
It all depends on what you are supplying.
Back to top
 Alert Moderators
helensmith1
from United Kingdom
PostPosted: Mon Nov 03, 2008 7:23 pm Reply with quote
Hi Norcon
I want to increase the flow of hot water to two upstairs bathrooms one about 30 feet away from the hot water tank and on the same level, I don't mind if the pump improves the hot water flow throught the house....I did e-mail Salamander and ask for advice but have heard nothing back and Stuart Pumps wanted to talk to my plumber but I think he's a clue leas as me, don't know if you can suggest anything suitable icon_wink.gif
Back to top
 Alert Moderators
Norcon
from United Kingdom
Thanked: 198 times
PostPosted: Mon Nov 03, 2008 7:58 pm Reply with quote
My only advice to you is get rid of the muppet who fitted the 15-90 and employ someone who at least knows that the pump is fitted between the cylinder and the outlets and will make a visit to your home and properly access your plumbing layout and advise accordingly.
Back to top
 Alert Moderators
muggles
from United Kingdom
Thanked: 517 times
PostPosted: Mon Nov 03, 2008 10:19 pm Reply with quote
I'll second that
Back to top
 Alert Moderators
helensmith1
from United Kingdom
PostPosted: Tue Nov 04, 2008 7:04 pm Reply with quote
thanks guys
you know thats really sound advice, however said muppet is a very close relative who will be very offended if I go else where.....you know what families can be like..... icon_rolleyes.gif but thanks for your advice....it still leaves me with the problem of either getting another Grundfos or something better.
Back to top
 Alert Moderators
rssteve
from United Kingdom
PostPosted: Tue Nov 04, 2008 8:16 pm Reply with quote
im supprised that when set to manual it wasn't just pumping water up the vent pipe back into the tank? where else could it have pumped it. And to say a plumber fitted it before the tank makes me think your having a laugh? icon_rolleyes.gif
Back to top
 Alert Moderators
helensmith1
from United Kingdom
PostPosted: Wed Nov 05, 2008 9:12 pm Reply with quote
Hi rssteve
no not a laughing matter the chap is a fully qualified plumber.......and you're right it was pumping back into the cold water tank I think...not sure why the sensor is not working on the pump when he moved it to the feed to the taps though,,,,all I know is its cost me a small fortune and no further forwards, icon_evil.gif
However on the plus side stuart turner have suggested a negative single pump either 2.5 or 3.5 bar, so I will give them a ring and see whats what, thanks guys.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Fit a booster pump to feed elec. shwr from cold water tank 8 1040 Tue Aug 01, 2006 8:13 pm
Hot water booster pump sucking CW through vent? 2 40 Sun Jan 13, 2013 7:56 pm
Booster pump for hot water? 2 700 Mon May 15, 2006 9:07 pm
should i fit a booster pump? 4 400 Wed Jun 25, 2008 3:24 pm
booster pump problems 4 420 Thu May 22, 2008 6:30 pm
DIYnot
