Hello,
I just want to double check the wiring on a supply for heating-(oil)boiler. If I wire it up in such a way that the call for heat using switched mains power at two points in the circuit, does it constitute bridging or some other problem? or is it like on a ring circuit where the current can flow from two directions?
The supply is in a radial lighting circuit and the other point is underfloor heating control in another room
Very simplified diagram of mains supply:
View media item 6252 [/img]
