I need help installing a new oven. Being a muppet, I ordered one without checking everything would be OK. So; first problem is fairly common:
The old oven runs from a 30A fused line (red switch on wall), to a pair of 3prong sockets, and plugged in. The new one needs hardwiring (3400W), so I need to convert the twin plugs to a hardwire socket. The complication is that the hob ignition is also a plug fitting. Questions:
-What size wire needs to be running from the wallswitch to the plug for hardwiring the new oven? (so I know if I need to replace it or not)
-How easy is the conversion? do I need to fit a completely new wall fitting?
-Where does the hob ignition fit in? Do I keep the twin plugs, keep just one plug (although its two plugs on one fitting), or hardwire the hob ignition into the new setup?
-I assume there are no complications with the legality of doing it myself?
OK, problem 2: The gas pipe to the hob slightly obstructs the new oven. Options:
-Get a Corgi guy in to move the plug.
-Mount the oven a bit forward, and make up a wooden 'gasket' spacer. (not so keen, it would look pretty village)
-Cut a bit out of the oven casing so it will fit
The latter is possible as the intefering region of the oven is just casing, no actual oven. Would this be OK?
If doing it myself is not an option, can anyone give me an idea as to the costs involved for the two bits of work?
Thanks very much for any help.
