BACKGROUND
Hi, I have this last week had someone in to install a thermostat on my hot water cylinder (it didn't previously have one) and a 3 port valve (I don't pretend to understand what this is for, but the problem it was aimed at fixing was the virtually constant overflow of very hot water from my hot water cylinder into the attic hot water tank.) In the past couple of months I have also had a new radiator fitted and been powerflushed but I doubt that would have any impact.
The main components involved are:
Baxi Solo 2 RF gas boiler (regularly serviced and pilot light still on)
Salus MV322 3 port motorised valve
Honeywell L641A cylinder thermostat set between 50 and 60 degrees
THE CURRENT PROBLEM
Two days after the valve and thermostat were fitted, my central heating has suddenly stopped working. It was going nicely all day, then cut out before the programmed time this evening.
I did a manual override to switch the timer off, then switched it back on and it came back to life and worked fine for about another hour.
It then cut out again and has since refused to come on at all. Absolutely nothing happens when the timer is switched on - usually there are a few clunks and groans and the boiler fires up and the whole system gets going, but now there is just the loud silence of absolutely nothing happening!
OPTIONS
I have three options - try fix it myself (my preferred option, given that it's the weekend and freezing cold, but only realistic if it's something really easy like a switch!), call back the engineer who fitted the thermostat & 3 port valve, or call out a British Gas engineer under the terms of my maintenance contract.
To help me decide which is the best course of action, I'd like to know is whether there is likely to be any connection between the installation of the 3 port valve thingie and the heating being on strike? Also, can anyone explain in words of one syllable what the 3 port valve actually does?
Would greatly appreciate any help - thanks very much.
(Incidentally, with the hot water cylinder set at 65 degrees, the water is still overflowing into the attic tank and the water in that tank was still quite warm earlier today - although not as hot as previously, I would presume it shouldn't be routinely overflowing at that temperature?)
THE CURRENT PROBLEM
OPTIONS
