- Joined
- 9 Dec 2008
- Messages
- 34
- Reaction score
- 0
- Country
Hi All,
I have a Worchester Highflow 400 boiler which is losing pressure of around a bar every couple of weeks. I have wooden and some tiled flooring on the ground floor where i suspect the problem may be (as i can see nothing on ceilings anywhere) and would at least like to try this stuff before i go ripping up floorboards and destroying tiling.
We have 2 floors and a converted loft above that with a radiator in it, i intended to use the Fernox leak sealer by draining water from the system so that radiator empties, injecting the Fernox into this radiator (i presume through the bleeding valve - is that right?) then filling up the system with water again and running.
I cant inject it at the inlet valve next to the boiler as im no plumber and it would involve disconnecting pipes etc so i presume injecting it into the top most rad would be the best move.
One other thing i wanted to ask, i have cold spots near the bottom of nearly all the radiators although some are worse than others, i've previously taken of the topmost radiator (the one in the loft) and flushed it through with a hose, quite a bit of dark filthy water came out, no clumps or rusty stuff though.
Im assuming the topmost radiator should be the best so i fear for the ground floor ones.
Would you recommend a powerflush? British Gas suggested a price of around 600 quid (we have 9 rads). Are there other who would provide this cheaper and are they as reliable?
Thanks - lots of questions i know.
