Unfortunately I didn't read the posts about Bathstore before and how bad they are so I am now having to try to fit a Euro Mono WC and have some questions if anyone can help and has experience of them:
1. Simple one... when I connect the cistern to the pan does the black coupling have to dissappear altogether? Is there any trick to doing this as the few times I have tried it never quite fits flush - even with a LOT of pressure on it...
2. The pan comes with 2 white v shaped brackets, 2 bolts with washers and white rawplugs and two screws with blue end caps on. How on earth do they work! I initially thought that the white brackets were screwed to the floor (with the bolts) and then the two screws with the blue caps went through the holes in the sides of the pan and into the white bracket. However I can't make that work - the white bracket has one big hole in one side and then the other side has a lot of small holes in it (think swiss cheese!). Has anyone installed the pan before and can help me out? Could I just put a white silicon seal around the base and sit it on that?
Cheers
Ricard
Cheers
Ricard
